Question about Nortel Norstar Audio Conferencing Unit (NTAB4213)
NorStar Audio Conferencing Unit has no dial tone, just lights blinking on/off. Was working less than 24 hours ago. Have tried unplugging and moving to anoither location, but problem persists.
2 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Blinking lights on Norstar audio conferencing unit
Hi.
First try a power reset, as probably suggested. This is done disconnecting the power adapter. If this model also uses internal removable battery, remove the battery for one minute, so to power down the unit completely. That won't probably fix the problem, but it is part of troubleshooting process.
More than proper phone programming, this units allow feature settings.
To access settings, find the Feature Activation Button. See picture below:
Using the Feature button try canceling conference call, in case the phone is jammed with old conference settings. Use second combination shown as Cancel below:
Try using restriction override, in case a restriction has been set:
If nothing else works, try starting a call to alternate line. Use Feature button and nr.2 before dialing the number.
I still no luck, there are additional microswitches at the bottom of the unit that can be checked. This settings are not supposed to be changed by the user. In this case before proceeding I suggest calling 1-800-4 NORTEL in USA, or call your local Nortel number listed in their website.
Here a user guide.
Regards.
Ginko.
Posted on Jan 13, 2011
I have not had a "dial tone" on my MJ for over 24 hours...can neither receive nor send messages. I unplupped it this morning from the elec outlet and left it unplugged for about 4-5 minutes..still no
Asumming this isn't an MJ Plus and it's interfaced w/your computer it sounds like the unit is defective. you should contact MJ to be sure of no issues on their behalf, though.
Jun 16, 2014 | Android Apps
The problem is with my uniden phone model D1364 can't hear the tone when dialing phone
If you can't hear the dial tone, try substituting another phone to detect it. Also, if your Uniden phone is defective it can disable the dial tone when connected to the line.
Mar 08, 2014 | Uniden DECT 6.0 Cordless Phone ID
No dial tone
Try swapping it with another working phone of the same type. This will tell you if the extension line is in trouble to the phone system or the phone.
Jan 02, 2013 | NorStar M7310 Corded Phone
Nortel Norstar 2501-03308-001 is blinking green lights but will not dial out or get a dialo tone. Can someone please help.
Mmm, same thing on me. It was working fine before but for no reason it now does that. Line was tested ok.
Jan 07, 2011 | Lands Phones
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Can't get the mesage light to stop blinking
You forgot to supply a model number, but is this a cordless with an answering machine or did the message light blink when you had messages from the phone company provided voice mail?
If it's the former, pressing the play button and/or holding down the ERASE button will make the messages disappear.
If it's the latter, here's where the fun begins. Message lamps are lit from a signal generated from the phone line. Stutter dial tone is usually the cause, and it could be just because you have a feature enabled. I think the cadence of the call forwarding dial tone is enough to set off MW, but I'm not there to hear it :-)
Try unplugging the phone completely, then plug it in without the outside line. I'm guessing the display will tell you there's no outside line, but what does the message waiting light do? Then plug in the line and see if it lights immediately or after some delay. It may test the line as soon as you plug it into the wall and be hearing the funny dial tone.
Comment back after you've done this.
Carl
Jan 07, 2009 | Uniden Cordless Phone
HP 640 fax
Are you plugged into the LINE port?
Oct 30, 2008 | HP 640 Inkjet Fax Machine
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
No dial tone and also all the lights are flickering, please Help!
Unplug and and plug back the phones and see what happens.
May 02, 2008 | NorStar T7316E Corded Phone
Lands Phones Logo
179 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
