Plantronics CS55  Wireless Headset Logo
Posted on May 05, 2011
I'm trying to recharge my headset but the green light remains on (I clicked on the botton on the headset piece but it won't turn off). When I try to turn it off, it beeps at me
hawk67m
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 05, 2011
hawk67m
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
4106
Points
33
Try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
My Acer KAV60 laptop won't turn on. When I push the power botton, it blinks green once then nothing.
Has the laptop been damaged? Dropped? Same on battery? Remove battery, try AC only. Try another cord/charger with the EXACT same power specs. Reseat Memory mods. Test the DC volt output, at the laptop plug in, with a multimeter. Power issues are difficult to diagnose long distance.
2helpful
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Well I have a Gateway Laptop Model MS2274 and it won't turn on. The light of On/Off is blue so it's on, but the screen remains pitch black. I connected it to recharge it and the light turns on too....
Try connecting an external monitor and see if your see anything. If you can then most likely your LCD monitor on the laptop is dead. Also try FN+ the monitor toggle key to see if you can get video.
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
How do i set up my hs50 b.t. on my boost mobile phone
Please try in this way, with the headset turned off, press and hold the call botton for 6 to 10 seconds until the blue light indicator turns on and remains steadly lit (pairing mode), then set your phone to look for devices, the headset should be found as Motorola HS50 (handsfree profile), select it and enter the password 0000 (four zeroes), this will pair (bond) the headset with your phone.
14helpful
3answers
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
