Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
The only way I can get the motor to work is to hook the power to one side of the switch and the motor to the other side. There are no other connections for the pump to attach to. So clearly I have the rocker switch wired wrong. Can you help?
