Question about Kingston Computers & Internet
I have a macbookpro unibody from mid june 2009. my brother gave me a kingston SSD (kingston ssd snvp 3532s2). The problem is hanging: beachballs.and i cannot get any data on the disk. downgraded firmware, which lets me send data to the ssd, but my mac still doesnt see its a harddisk. Cant solve it, hiope you can help
SOURCE:
The_PhoeniX
  • 156 Answers
SOURCE: RE: 2GB Kingston on MAC OS X
The drivers are needed only for windows 98 and back. Xp, mac all do not need drivers for the thumb drives.
May be something else is wrong... mostly software related.
Posted on Apr 12, 2008
  • 53 Answers
SOURCE: usb not recognized?????????
The USB port in which your flash disk has been inserted muight be damaged. Try inserting it in another port.
Posted on Oct 22, 2008
  • 52 Answers
SOURCE: 32 gb kingston pendrive makes my laptop hang
This is a bug from the operating system, turn off you're laptop, plung the stick and power on the laptop.
Posted on Dec 16, 2008
craigjamesbt
  • 65 Answers
SOURCE: How do I (on my MAC) format my kingston data traveler 512mb?
when you send items to the trash in finder. it places a trash extension on the files and saves them so to remove the items permanently you must empty the trash you can empty it while the disk is attached but be aware that when you empty the trash it will remove all .trashes including those on the hard disk so make sure to check the trash can for files you may need ahead of time also if this does not correct the problem you can connect the disk and open /applications/utilities/'disk utility.app' select the disk on the left then choose the erase tab at the top of the box I am not really familiar with these jump drives (I don't use them) but I would imagine you can use any format although for the disk to show up on mac and windows computers you must format to a ms-dos(fat) file system
Posted on May 01, 2009
ib_yang
  • 1098 Answers
SOURCE: Hi there, I have a
Welcome.
First of all, check the flash drive if it has a slider somewhere. Some flash drive has this slider as a write protect switch. If it has none, this is a problem with XP, do the following:
1. Run an anti virus/spyware program while the USB flash drive is inserted.
2. If the above does not work, try this:
Run > type regedit > Enter - Single-click on 'My Computer' > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
Double click on the string 'WriteProtect' and change the 'Value Data' box to '0'
- Then: File > Export > save somewhere useful as something like 'StorageDevicePolicies001.reg
- You also need to do this for the strings in any folders called 'ControlSet***' (* = any Digit, i.e. 001, 002) - for example: Everything is the same, just change 'CurrentControlSet' to 'ControlSet***
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolicies
Save these to the same place as before as 'StorageDevicePolicies00*'
The saves are in case it reverts at a later date, just double click (saying 'yes' to importing these to the registry) on all of the files and it will all work again.
Hope this helps. Let me know if you need further assistance.
Posted on Nov 18, 2010
What are the things you need to be aware about before buying an Solid State Drive SSD?
is it sata enabled
is it big enough for the application ( GBs)
is it of quality manufacture
Kingston is a good brand , economical to buy , it is Sata rated and a 125 gb will replace a 250gb disc hard drive
Like all things , talk with a computer repair shop
Oct 14, 2016 | Sony PlayStation 4
How to clone an hard disk
If you're trying to clone 8.1 to a hard drive or SSD, Macrium Reflect OS migration to SSD does a pretty good job. I've had several successes with it and some failures. If you're cloning to a SSD, I suggest using a Kingston with Macrium Reflect; it appears to be better suited for the software and has the highest success rate.
Macrium Reflect is free, or pay if you wish. Make sure you burn a rescue CD; you will likely need it to finish the cloning process for your cloned drive. It is required to clear up the errors.
http://www.macrium.com/reflectfree.aspx
Mar 11, 2015 | Microsoft Windows 8.1 Pro - Windows
How to install ssd in asus s500ca
Am not an expert in this area. I have a different laptop. I swapped my HDD with ssd.
U just have to open up ur laptop.
Basically ssd can be mounted in three ways. Depends on how ur laptop hardware is arranged and what kind of ssd you install.
U can either mount ssd instead of current HDD, or swap ur optical drive with an ssd or even swap ur WiFi Bluetooth card with ssd. First open up ur laptop. Plenty of videos are available in YouTube, on how to dismantle it. Then choose what type of ssd and simply install it. All the best.
Jul 15, 2014 | ASUS Computers & Internet
Upgrade ssd on Samsung NP900X3F
INTEL
KINGSTONE
Samsung are the best brands depends on your budget and arability in your area.
Mar 10, 2014 | Samsung NP900X3F-K01US I5/1.8 4GB 128G SSD...
My new SSD is corrupting 10.6.8 OSX
I would say if it's new and not working properly, just return it for a new one under the warranty.
Jan 05, 2014 | Samsung 840 Pro 128GB, SSD, notebook
C654 ssd reset
Many users have installed Windows 10/8/7 on a solid state drive (SSD) to get better read/write speed and boot speed. You may want to reset SSD to factory settings and start it over when your SSD is running slow or when you just want to dump it.
As you know, like USB flash drives, SSDs have a limited number of times that you can write data to. Therefore, you cannot reset SSD to factory default using the way of wiping hard disk drives (HDDs). How can you remove all data without hurting the SSD? You can perform a SSD Secure Erase.
An SSD is most likely your boot drive, so here we will show you how to erase SSD without loading Windows 10/8/7. You need to prepare a writable USB flash drive or CD/DVD to create a bootable disk. 2GB of space is enough.
1. Download and install AOMEI Partition Assistant. Connect a USB drive or CD to your computer.
2. In the main interface, click Make Bootable Media from the left panel and follow the wizard to create a bootable media.
3. Reboot your computer. At startup, press a specific key (F2 or Delete) repeatedly to enter BIOS and then change first boot order to the bootable disk you just created.
4. Then it will load AOMEI Partition Assistant. Click SSD Secure Erase and click Next.
5. Select the SSD that you want to reset to factory settings and click Next.
6. Confirm the SSD identification information just in case of deleting the wrong SSD. Click Next to continue.
7. In the next window, you will probably see the SSD is in Frozen state and it cannot be unlocked. Then you should perform a hot swap for this SSD just as instructed.
8. After reconnecting the SSD, click OK to start the Secure Erase for your SSD.
n seconds or probably milliseconds, you will see the SSD is a block of unallocated space and then you have successfully reset SSD to factory settings. Before you install Windows, you can use this freeware to partition the SSD and format SSD as you like.
Feb 28, 2013 | Konica Minolta Office Equipment & Supplies
Can I install a kingston sdd and install windows 7 to it?How do I get to the Hdd?Also what is the advantage of having windows7?
The HDD can be accessed/removed from the underside of the laptop. If you look at the bottom of the laptop, there is a rectangular panel in the corner (farthest away from the battery). Remove the screws holding the panel in place and lift up the panel. Underneath is the HDD. If you remove the wrong panel (the large odd shaped one), you will be looking at the two RAM modules.
You can certainly replace the old HDD on the Toshiba with an SSD. Windows 7 works very well with SSD's as you won't have to worry about installing drivers or any special garbage collection software, as these essential SSD features are already present in Windows 7. The most essential feature Windows 7 will offer for your Kingston SSD will be the TRIM command, this runs in the background and greatly improves the lifespan of your SSD (read more detailed info about this here).
Other advantages of Windows 7 is the improved security over previous versions of windows, and more importantly, no performance issues that plagued Windows Vista. Not to mention the thousands of applications available for Windows. There are of course, many visual features that are fun to play around with in Windows 7, but that's about as far as I will go to summarize the functionality.
Good luck and have fun, I installed a very similar Kingston 64gb SSD on my own laptop and I have yet to regret it (they are fast).
Jan 23, 2011 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
