Hello Sir
In Idle mode, press and hold # to silence or
unsilence your phone.
And To change Your Ringtone follow these steps !
Change your ringtone
Phone ? Settings 1. In Menu mode, select
profiles .
2. Scroll to the profile you are using.
> Voice call ringtone ? Edit
Hi, you can mute the incoming call's ringtone by pressing the Volume Key at the side of the phone to downwards to Mute it and upwards to unmute or increase the Volume. You can also mute during the call progress, please select options and select Mute, to Unmute select the same option. Just press the # key for few seconds to make the cellphone to silent mode and press the # key again to disable Silent mode.
Press "Hold" to place a call on hold or press "Retrieve" to retrieve a held call.
You may contact your network
provider Samsung S7220 Unlock Code. I suggest you to visit Samsung Unlock Code
site, they will provide you an accurate code fast with easy to follow
instructions on how to unlock your phone. Once your phone is unlocked, it will
work with any network worldwide and don't have to stick to one network.
Hope this is helpful.
Thanks.
