GE 14.8 cu. ft. General Electric Chest Freezer FCM15PUWW Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DOES NOT FREEZE - GE 14.8 cu. ft. General Electric Chest Freezer FCM15PUWW
Anonymous
Level 3:
Genius:
  • Master 1,156 Answers
  • Posted on May 07, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1156
Questions
0
Helped
278176
Points
3203
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem...
1helpful
Can you freeze cheese
Yes and no.
Pick a cream cheese that is medium to high in fat and you can freeze it. It will alter the texture slightly but the taste remains the same. When thawed the cheese will be more crumbly than creamy, but still ok for eating as is, or even better for casseroles and dips etc.
Pick a cream cheese that is high in fatjjj Low and non-fat cream cheeses will not freeze very well.
Although it's completely possible to freeze cream cheese, it does alter the texture. Thawed cream cheese is less creamy and a lot more crumbly than fresh cream cheese. Because of this, it's best to use frozen cream cheese in casseroles, baked dishes and dips.
Pick a cream cheese that has a higher fat content. Low and non-fat cream cheeses don't freeze as well
Dec 27, 2013 • Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
What indicate liters in freeze?
The liters indicate the storage capacity. The more liters there are, the higher the strage capacity.
1helpful
Can only get freezer to work when quick freeze is turned on
Your thermostat is faulty. Run it in fast freeze mode until you can get it replaced
May 04, 2012 • Freezers
My Upright Freeze is not getting cold after it was plugged in
dear sir/madam
please check your freeze,s compressor is working if it,s then there can be low gas problem for further action please contact to freeze maintenance personnel .
hope answer the question
thank you
please vote!
1helpful
About the orange light button - quick freeze?
yes it is a quick freeze it bypasses the thermostat so if u have any new items that need freezing quickly this will do it. But remember to turn it iff as soon as you can otherwise it will start to freeze the whole appliance.
Mar 13, 2010 • Freezers
Sanyo Frost Free Fridge (Model SR 1031) very slow to cycle through freeze to defrost back to freeze cycle. The temp in Freezer compartment goes from -17 degrees to -1 degree then back to -17 as it takes in...
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
Feb 10, 2010 • Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
2answers
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
