Question about Elgin Calendar Day/Date w/Crystal Goldtone Case/Black Dial & GT Link Band Watch for Men
I JUST PURCHASED AN ELGIN WATCH FROM THE AVON CAMPAIGN 11 BROCHURE. IT DIDN'T COME WITH ANY INSTRUCTIONS. IS THERE A MANUAL FOR IT... IT DOESN'T HAVE A MODEL NUMBER ONLY DISCRIPTION OF BOLD CHRONOGRAPH WATCH....HOW CAN I GET A MANUAL FOR IT?
  • 1 more comment
  • Brian Moat Jan 05, 2012
    For lack of a better manual (the manual came with the watch, but it is so tiny, you probably didn't recognize it as such...), I shall attempt to write down the usage of the buttons and how to set the 'Bold Chronograph' Elgin watch from Avon.
    First there are 4 buttons, because they have various functions, for the sake of simplicity, I will refer to them as LU (left upper), RU (right upper), LL(left lower, and RL (Right lower) buttons, this is as the watch is worn, with the 12 facing away from the user.
    1. To set the time: Press the LL button 3 times, and the upper circle (seconds) will flash the number being displayed. Press LR button until minutes are displayed flashing, then press UR button until proper minute is showing. When proper minutes are set, push LR button 1 time, and hours should flash. Push UR button until proper hour is displayed. NOTE: when cycling through the hours, watch will first run 1-12am, then 1-12pm, THEN 1-24 hours, so be aware of this if you are in 24 hour mode and you wish to change to 12 hour mode.
    Press LR button 1 time after proper hour is displayed, and date will flash in center circle, press UR button until proper date is shown, then press LR button once again to cause month to flash in bottom circle. Press UR button until proper month is displayed, then press LR button once, and black bar will flash in upper circle (this is the day of week indicator, if you look very closely at circle of face surrounding this circle, you will see (from 12o'clock positon clockwise) Mon, Tu, Sa, Fr, Th, We, and Su, push UR until proper bar for proper day of week is flashing. Then press LR button once, and corrct time, (hours, minutes, seconds and day of week) should be displayed, with seconds (top circle) flashing. Pushing UR will reset seconds (ie for co-ordinating watches), or pressing LL will exit watch setting function,
    2. To set alarm: press LL 2 times, watch will display 'A' in top circle, and bottom circle will flash, press UR until desired hour is displayed, NOTE: changing alarm time will automatically arm the alarm function, I will cover arming/disarming alarm later... once desired hour is displayed press LR once and minutes will flash, press
    UR until desired minutes are displayed, Press LL button, and watch will return to normal operation, however; you will note black bar at bottom of middle circle, this indicates that alarm is armed, to disarm alarm, press and hold LR, and press UR while holding LR and alarm function will toggle from armed to disarmed, do same to activate alarm.
    3. Chronograph function: Press LL once and 00 will show in all 3 windows, press UR to start/stop chronograph, pressing UR will stop chronograph and 'pause' counting, pressing UR again will resume counting where it was when UR was pressed prior.
    If chronograph is running and LR button is pressed, display stops, but counting continues (ie. lap timer), so that when LR is pressed again, display will resume with display of 'unpaused' count.
    When UR is pressed, and LR is pressed thereafter, chronograph will reset to all 0's, from there, pressing UR will restart counting, or pressing LL button will return watch to normal display funciton.
    I have heard rumors that the watch can be set to display the date by default in the digital displays, but from my experimentation, I would guess this person has gone through the 'time setting' steps above until they came to 'setting the day of the week', and rather than continue from there, which resets the watch to normal display, they leave the watch displaying the date, with the day of the week flashing. I would not recommend this, as it prevents you from using the other functions of the watch properly, and it probably runs the battery low unneccesarily quickly.
    Press
  • rsvoodoo
    rsvoodoo Dec 10, 2012
    Thanks, my problem is son set it so on the hour it beeps, how is this turned off? thanks
  • spazzoid3 Jan 10, 2013
    how do you see day and month on watch
    New Friend:
Need a clear size manual to set the chronograph watch time
Posted on Jun 06, 2011
  • brendasha780 Jun 06, 2011
    I bought it from Avon
    how do you see month and date
    New Friend:
Here is manual for quick vew I JUST PURCHASED AN ELGIN - 72481702-1e51-40f6-a87e-20418a57c27f.jpg
Posted on May 26, 2014
Thanks man my watch was going off alarm.and I couldnt figure out how to turn it off so thanks
Posted on May 24, 2012
    New Friend:
Can someone email me that picture? I can't read it very well.
Posted on Dec 14, 2015
    New Friend:
Carlos can you upload the full manual
Posted on Sep 24, 2014
SOURCE:
How to set the time on an Elgin Gps2000s
Google (elgin)(Gps2000s)(manual) without parens for instructions.
Sep 05, 2018 | Elgin Watches
I have an new Elgin wristwatch the is radio controlled. It doesnt have a manual... It has two buttons on the right side with a crown in the middle right. It needs to be told EST signal helP?
Hello, Chipper -
Currently watches with the Elgin name are manufactured by M. Z. Berger & Co. I found the company web site and found information regarding how to obtain instructions for an Elgin brand watch the company manufactured.
http://www.mzb.com/customer-care
From the company Contact Us web page, this is the phone number to call:
(718) 472-7500 ext. 7546
Long Island City, New York (Eastern Time zone)
Best wishes.
Jan 23, 2018 | Elgin Watches
How do you set the time and date on the Elgin fg 117
Try Googling (elgin)(fg 117)(manual) without parens to get instructions.
May 18, 2017 | Elgin Watches
Do you have Manual?
http://www.ehow.com/how_6179645_set-elgin-watch.html
Mar 08, 2015 | Elgin Calendar Date Watch
Setting chimes and time for elgin e77
I thought I had some instructions on that Elgin clock, but it was for a mechanical wind up unit. There were many different models of these programmable clocks manufactured and the instructions differed. And they are just not readily available. I received a sports watch in a trade (with no instructions)and after 3 months I am still trying to determine how to program it!
It might be that the "H" stands for hours and the "S" for set. So how do we set the minutes? I will pose this question to my Internet Clocksmiths Group and see if anyone knows. If I do receive some instructions, I will get back with you.
Buy Performance Parts.
Jun 04, 2012 | Elgin Watches
I own an Elgin man's wrist watch with quartz movement. It has the N, S, E, & W, on the cover together with" 30 NE 60, 120 SE 150, 210 SW 240 & 300 NW 330. It's water proof to 30 meters. Stainless...
I think it maybe the same watch that i had purchased years ago. I have an Elgin D275A Wrist Organizer Calender World Time Telememo Scheduler Ana-Digit and yes i do have the manual and i have a scanned copy of it i can send you. It's an impossible watch to find now. you can email me @ jdonohew@yahoo.com
Apr 01, 2010 | Bulova Watch
How do you open the back of an antique Elgin pocket watch
You might be able to pop it open with a pocket knife ... don't stab yourself though.
Mar 08, 2010 | Elgin Circa 1904 Watch
I JUST PURCHASED A NEW ELGIN LADIES WATCH ONLINE AND IT NOT WORKING. WHAT DO I DO?
If you are able to, send it back where you got it, most companuies have 30day return policies...if its been longer take it to a reputable jeweler or watchmaker and have the battery replaced...sometimes watches have been sitting in a warehouse for awhile before they are sold and the batteries have run down.
Nov 09, 2009 | Elgin Watches
Elgin Calendar Day/Date w/Crystal Goldtone Case/Black Dial & GT Link Band Watch for Men Logo
4,248 people viewed this question
Top Elgin Watches Experts
jdthefixer
Are you an Elgin Watch Expert? Answer questions, earn points and help others
