Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414 Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Anonymous
Level 3:
Genius:
  • Master 1,156 Answers
  • Posted on May 07, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1156
Questions
0
Helped
278173
Points
3203
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
My freezer gets cold on the bottom but does not freeze anything. I never hear the fan come on. I replaced the thermostate but still the same. What part should I try next. I have model FFU14FC4CW1
If the compressor comes on the thermostat is good, what you need to check is for power to the fan in the freezer, if power present at fan but it doesn't run the fan motor is bad.
Gene
It is not wanting to freeze. but it does keep things frozen. and some times water does come out at the botton
Hello
Check that it set cold because its not below -2 or -5 thats why dose not freeze anything it needs to be at least by -10 to -18
Someone left the door open on the freezer and all the meat went to waste. The problem I'm having is the freezer only gets cold and will not freeze anything? I have no Manuel, and the unit is only...
Same thing happened to me, turns out the compressor when bad at the same time the door was left open, it was pure coincidentally, had nothing to do with the door being left open.
My freezer is a little cold but wont freeze anything?
You freezer has insufficient refrigerant and need to top up. You may have the leaks on pipe line.
1helpful
Deep Freeze not freezing
this could be from a faulty temp controller however my best! bet is it's low on froen due to a high pressure leak
We put things(meats,water,veg.) anything but
check the cold deflector door for proper operation, then check the cold control itself as it may be defective
Nov 01, 2009 • Freezers
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 • GE Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
