Computers & Internet Logo
Posted on May 04, 2011
Where can i obtain user instruction manual for grecom psr 295 radio scanner ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
316
Points
I think this Instruction Manual is what you are looking for.
Internet Web link below.
http://www.greamerica.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=1020
How to program and tune a Grecom 200 desk scanner.
Question edited for clarity
Question moved from GPS to model category.
Gre PSR-200U Manuals
ManualsLib https://www.manualslib.com > ... > Scanner
Gre PSR-200U Pdf User Manuals. View online or download Gre PSR-200U Owner's Manual. ... We have 1 GRE PSR-200U manual available for free PDF download: Owner's ...
GRE PSR-200U OWNER'S MANUAL Pdf Download
ManualsLib https://www.manualslib.com > ... > Scanner > PSR-200U
Feb 22, 2010 - View and Download GRE PSR-200U owner's manual online. 200-Channel plus 20 FM Channel VHF/Air/UHF Desktop Scanner. PSR-200U scanner pdf ...
To GRE Manuals
RadioPics http://www.radiopics.com > 1. Manuals > GRE
GRE MANUALS. * MANUALS * ALWAYS * WANTED *. Please Mail Me if you have a Manual ... PSR-200U · Manual (506 Kb). PSR-214 · Manual (1.27 MB). PSR-225 · Manual (526 ...
GRE Manuals - Home - KO4BB
ko4bb.com http://eww.ko4bb.com > getsimple > GRE_Manuals
Manuals ; PSR200U-Manual · PSR216OM ; PDF · PDF ; 508K · 520K.
Programming Your GRE Scanner
Radio Reference https://wiki.radioreference.com > index.php > Progra...
Jan 13, 2019 - The manual is very hard to read/confusing/worthless. Are there any better ones? Welcome to the Programming Your GRE Scanner article. At some ...
What can a GRE/PSR_255 scanner receive?
Question edited for clarity, "i before e except after c".
PSR-255 GRE Handheld Scanner
* Frequency 26-54, 66-88, 137-174, 380-512MHz
* Modes AM, FM * Memories 50 + 1 monitor
* Search speed 50 steps/sec * Scan speed 25Ch/sec
* Scan delay 2 secs * Priority channel
* Antenna rubber duck, BNC * LCD
* Audio 200mW into 8 Ohms int. speaker
* Power 6 x AA (not included), ext. power 9V DC
* Size 171 x 59 x 40mm
* Weight 240g with ant & batts
PSR-255 50-CHANNEL SCANNER OWNER'S MANUAL
-> RadioManual.eu <- http://www.radiomanual.info > schemi > GRE_...
Your new PSR-255 50-Channel Portable Scanner gives you direct access to over 26,000 exciting frequencies, including police and fire departments, ...
24 pages
PSR-255 - GRE / GRECOM
Rigpix https://www.rigpix.com > gre > psr255
May 18, 2023 - Type: VHF/UHF receiver/scanner ; Frequency range: 26-54 / 68-88 / 137-174 / 380-512 MHz ; Tuning steps: 5 / 12.5 KHz ; Frequency stability: ? ppm.
GRE PSR-255 Owner's Manual (Page 2 of 24)
ManualsLib https://www.manualslib.com > ... > Owner's manual
View and Download GRE PSR-255 owner's manual online. 50-CHANNEL SCANNER. PSR-255 scanner pdf manual download. FEATURES Your new PSR-255 50-Channel Portable ...
Albrecht AE55H / GRE PSR-255
Discriminator.nl https://www.discriminator.nl > index-en
The discriminator IC of the Albrecht AE55H and the identical GRE PSR-255, a Motorola MC3361, is hidden below a crystal (marked 10.245).
PSR-255 GRE Handheld Scanner - radioworld
Radioworld UK https://www.radioworld.co.uk > psr-255_gre_handhel...
PSR-255 GRE Handheld Scanner * Frequency 26-54, 66-88, 137-174, 380-512MHz * Modes AM, FM * Memories 50 + 1 monitor * Search speed 50 steps/sec * Scan speed ...
£64.94
Handheld radio scanner frequiencies help
Go to "RadioReference" dot Com and you can get frequencies for your area.
What are the frequencies for a grecom pro 255
Hi Tracy,
If you are looking for frequencies to program into your radio scanner, try this: www.radioreference.com, they have the best online state by state listing for the USA.
Cheers,
Peter
1helpful
Can the GRECOM PSR255. be used to scan for aircraft /airband frequencies
Your radio is not capable of recieving air band frequencies. It will only receive 4 bands consisting of: 26 - 54 MHz; 68 - 88 MHz; 137 - 174 MHz and 380 - 512 Mhz.
The VHF airband uses the frequencies between 108 (just above commercial FM radio) and 137 MHZ (just below 2 meter Ham radio). Amplitude Modulation ("AM") is the mode that transmissions are made. The lowest 10 MHz of the band, from 108-117.95 MHz, is split into 200 narrow-band channels of 50 kHz. These are reserved for navigational aids such as VOR beacons, and precision approach systems such as ILS localizers
Grecom psr-200 .when scanning weather chanel comes in .what is problim.
IF you have a weather frequency programmed in as a scanning channel, it will stop on it everytime, so you need to go to 'manual' on the weather channel, and press 'lock-out' so that it isn't on during scanning. You can still manually go to that channel, but it won't stop while scanning that way. Good luck.
4helpful
GRE prs 295 channels locked out
This message usually means that the scanner has been cleared of all programming. Press the MANUAL key repeatedly to review channels. If 000.0000 shows, it means that you need to program the unit.
Need the manual for your scanner? You can download/print it here:
http://www.greamerica.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=1010
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Grand Canyon Tech
Grand Canyon Tech
