Its can be defrost problem.But still whats the exact model number of the unit.As per that the exact problem can be detected.
Is it old model or new model.?
Is there any water leak noticed in fridge section , then yes its defrost issue.------
--- Keep updated with details.
Ok, freezer is working but fridge not cooling.
follows: ----
color:black;mso-ansi-language:EN-US;mso-fareast-language:EN-US;mso-bidi-language:
AR-SA">First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. It will take near to 4 hours to get run in its
proper cooling cycle. Then check, if the problem returns again.------------ If after manual defrost, the problem is same, then see if the fan in freezer section is running or not running.Actually it should run.If its not running, that means the fan is the issue.The fan is in the inner panel side of the freezer.The inner panel has to be removed.
Model #GDS18SBRALSS, serial #TG900135V. We bought this Heartland refrigerator approximately 5-6 years ago. There is no water leak in fridge section.
