SOURCE: nuvi 660 audio update?
This series of Nuvi has 2 sets of voices for several of the available languages. The standard set is pre-recorded words linked together to form directions. This voice is usually clearer. However you lose street names and expanded vocabulary. The Text-To-Speech (TTS) voices are reading letters to form words, and uses an algorithm to come up with the approximate pronunciation of the word. This may sound less clear, but provides street names. So, you can select a standard voice (settings-locale-voice language) and lose some functionality, or select one of the many TTS voices and try to find one that doesn't offend the ear.
SOURCE: No Product Key to complete Garmin c330 update download
If you purchased the DVD Update version, the Product Key that they are requesting is on a label on the back of the DVD case that contains the update DVD.
If you downloaded the update they were supposed to e-mail you the Product Key.
SOURCE: how to update my 1 year old garmin c330
From a PC, load USB drivers, connect Garmin, run webupdater, follow on screen prompts.
SOURCE: Garmin radar error code 8
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
Have u checked with the antenna terminals... i suggest u to remove antenna contacts clean them using WD-40 for best and put them back.. Hoping to hear form u ..
Thankyou
