HP Color LaserJet 2600n Printer Logo
Posted on Aug 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP2600n image faded. Have cleaned mirrors and lenses with no effect. Have swapped cartridges and no effect. Image is denser on the left of the printed page and faded and patchy towards the right and thats with all 4 colours. Could it be the ETB at only 4000 copies? Have had a couple of leaks of toner and cleaned the ETB with damp cloth in the past. Could that cause the problem?
Dimitar Todorov
Level 2:
  • Expert 241 Answers
  • Posted on Nov 01, 2017
Dimitar Todorov
Expert
Level 2:
Answers
241
Questions
Helped
193119
Points
788
The laser/scanner assy has two motors with rotating mirrors on them. Did you cleaned their tiny reflecting sides? Dust collects on all sides the same uneven way due to air vortex around. Also check again all mirrors and the back of the lenses too. These printers tend to suck dust trough the lower fan and spread it into the right side of the laser/scanner assy. I usually remove the black plastic fan grate and cover the hole with tape to stop the dusty air coming inside. This fan is unnecessary for the printer, but the ECU checks for its rotation and if detached will give error. Also don't try to seal the L/SU to prevent the dust - will not help.
Dominion Computer Solutions, Inc.
Level 2:
Champion:
  • HP Expert 312 Answers
  • Posted on Oct 02, 2017
HP Expert
Level 2:
Champion:
Answers
312
Questions
Helped
98880
Points
457
4 Related Answers
ajay53
  • Posted on May 01, 2008
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Anonymous
  • 15 Answers
  • Posted on Jul 21, 2008
SOURCE: MAGENTA TONER IS FADED
This problem is a fairly common one and it is a tough fix. The laser unit has 4 lasers inside that shine off mirrors. The magenta mirror is on the bottom facing up and so gathers the most dust. The black mirror also faces up but is higher up and seems to not collect as much dust but it can experience the same problem. If you go to this HP forum
http://forums12.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1216658405809+28353475&threadId=1230246
you can read about the problem. Also you can search ebay for HP 2600 MAGENTA REPAIR and find a solution.
Anonymous
  • Posted on May 25, 2009
SOURCE: Magenta fades, need mirrors cleaed, need instructions
Sir,
Please see this website:
LINK
I just cleaned the mirrors in my HP 2600n printer using those instructions. It takes about 2 hours to do, but it's easy if you just go slow and careful and follow those directions.
Anonymous
  • 9 Answers
  • Posted on May 11, 2011
SOURCE: HP2600n - red prints faded
This is a common problem on these printers, the solution involves taking it apart which may not be for you but if you fancy giving it a go then follow the instructions in the PDF below from HPs site...
http://h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/141987/1/298322.pdf
2helpful
3answers
A white streak appears on the right hand side of the print out
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
1helpful
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Good Luck!
CreativeTECH
Faded print on right hand side
Hi Tracy,
Good Luck!
CreativeTECH
1helpful
My HP2600N colors are offset from the black - Alignment mode does not help - replaced toner with genuine HP toner cartridges and same problem.... Any Ideas ?
Mirror dirty laser scanner
The laser mirrors get dirty due to many things, the main blame lies about hp, and who had no rubber gaskets to "optical box" as it says, and the dust that comes in, causing us to blow a printer or same internal fan of the printer is stored in the bottom of the printer to finish the last piece together the laser mirror is the magenta, and that's why when the printer form the mirror image and transfer it to go faulty because the mirror does not project well in the dust which is on the surface. Thus forming the image pale color and lack of final results.
What should we do?
Clean mirrors, p ut to reach them we must completely disarm the printer, which is why I will leave some links to download the manuals.
1) Service Manual Printer hp2600n (English), just for reference but also helps explains how to get to certain parts of the printer, and tell us where are all the sprig, I recommend first ojearlo
I downloaded here: http://cid-4c0169bf00ee97eb.skydrive.live.com/browse.aspx/Manual% 20of% 20servicio% 20Hp2600n? Uc = 1
Now lower the compressed file that says "LaserJet 2600n Series
2) Manual cleaning of the laser (translated into Spanish), I was compiling info from www.hp.com www.fixya.com and forums, there are people who have disarmed the printer, and good will compile this information and there is a detailed manual with photos and 23 steps, and also gives details of the tools to use.
Click Here http://cid-4c0169bf00ee97eb.skydrive.live.com/browse.aspx/Manual% 20of% 20servicio% 20Hp2600n? Uc = 1
Now lower the word document that says "dismantling the printer to clean the laser"
Red prints a faded orange to yellow even though new toner cartridges have been installed? Any suggestions
imagen.jpg?w=399&h=138Well look this picture, (the children) are exactly the same, printed with the same cartridges are just in different printers. The right has all its correct tones, and the left is pale, clear, as if he lacked the magenta hue.
What should we do?
I bought a used Color Laser printer, the HP1600, and I have just installed three brand new color cartridges. When I attempted to print the color came out washed and very faded and you could see it being...
This could a problem with the laser scanner assembly. It gets contaminated with toner and dust so reduceing the laser intensity which in turn causes the image to be fainter and gives it a washed out appearance. You would need to remove the scanner and clean the lenses and mirrors for each toner cartridge. The laser scanner box is one unit with four mirrors and four lenses in it.
2answers
Magenta is weak/fading out
Well there is something that is getting on the lenses of the laser which is causing it to block the left side of the image. NEVER use that canned air stuff on LaserPrinters because this is what happenes to them if you do. The exess toner goes right onto the lenses and you have to take them apart to be cleaned.
Poor print quality....bad fuser???
Is the toner sticking to the paper? This could produce double images (but not mirrored) More likely a problem with a mirror in the write unit out of place, which could create "mirror" image and poor quality.
5answers
Printing
Check the print quality setting on your computer when printing from printing preferences try quality. Also optionally you may want to consider reinstalling the driver,s and uninstalling the printer completely first, as this will restore it to defaul settings.
k24674
Grand Canyon Tech
Grand Canyon Tech
