Sewing Machines Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on May 07, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
31914
Points
167
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
Testimonial: "thankyou"
BJ sewing
Level 2:
Champion:
  • Husqvarna Expert 300 Answers
  • Posted on Feb 15, 2013
BJ sewing
Husqvarna Expert
Level 2:
Champion:
Answers
300
Questions
0
Helped
88047
Points
429
You wound the bobbin with thread that was threaded through the machine, because Husqvarna tells you that you can do it that way. Well Husqvarna is dead wrong and they should not be telling people that. It puts too much tension on the thread that is winding onto the bobbin, it crushes the bobbin onto the winder spindle, and often causes the bobbin sides to expand and pop off, (explode).
DO NOT pry it off as suggested above, you will probably break the bobbin winder and cause an expensive repair.
Simply unwind the bobbin by hand while the bobbin is still locked onto the winder spindle. You can remove the bobbin after you take the thread off and throw away that now ruined bobbin.
NEVER wind a bobbin with thread that in threaded through the machine, the thread has to come off the spool, through the guide and onto the bobbin.
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Bobbin winder not working
The thread needs to be hand wound on the bobbin first. Then hold the thread tail while activating the bobbin winder. There are machines that automatically wind bobbins but they are specialty machines and have no external bobbin winder mechanism.
Bobbin tension Viking Freesia 425
Take a look at www.sewingpartsonline.com and check out bobbin case for your model. Does yours look the same? If so, look up how to adjust bobbin case tension on www.youtube.com.
1helpful
Settings for stippling freesia 425
Lower feed dogs. Turn on Needle Down. Presser foot pressure on Darning setting. Don't forget to lower the presser foot lever. That's about it! Since you are going to be the feed dogs, it doesn't really matter if you have a stitch length set or not, but do have width set for "0". The spring loaded darning/embroidery/quilting foot is the best for stippling, but try it with any open toe foot you may have. Do a few samples first using the threads you intend using on your project because the tensions might need tweaking. Try to get the result you like by adjusting only the top thread tension. If you really have to adjust the bobbin too, put a small mark on the bobbin case where the "normal" position of the screw is so you can return to that when you are done quilting.
No tension on bobbin thread
You might remove the bobbin assembly looking for a broken tension spring (maybe a piece of it lying in the bottom the bobbin case.
1helpful
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
