Question about Jacuzzi Submersible Pump, 12 Gpm 3/4 Hp 2 Wire
We recently bought a second hand but unused whirlpool bath. It had never been attached to an electrical connection and did not come with a wiring plan. The pump is a Astra Padova Venus 1000 model with four wire coming from it. Although we have had two electricians look at it they are reluctant to wire it without a wiring plan as they are unsure about the four wires. Can you help please
  • 565 Answers
I tried to find the Astra Padova Venus 1000 model without any luck.
All motors have a nameplate. It is either metal or a sticker. If you can provide the manufacturer, cat # and/or part number from the nameplate on the _pump_ motor we should be able to look it up.
The nameplate will look like this: http://www.google.com/imgres?imgurl=http://www.poolcenter.com/images/centmagnameplate.jpg&imgrefurl=http://www.poolcenter.com/pumps.htm&usg=__uOeUWPwZjFnmO8F2KNl3n-k3GIM=&h=417&w=488&sz=32&hl=en&start=15&zoom=1&tbnid=cSU5ie-8i0stWM:&tbnh=123&tbnw=155&ei=NCHCTc-2OYXB8QPY67zbBQ&prev=/search%3Fq%3Dmotor%2Bnameplate%2Band%2Bdiagram%26hl%3Den%26sa%3DG%26biw%3D974%26bih%3D574%26gbv%3D2%26site%3Dsearch%26tbm%3Disch0%2C603&itbs=1&iact=hc&vpx=122&vpy=222&dur=1346&hovh=207&hovw=243&tx=120&ty=125&page=2&ndsp=15&ved=1t:429,r:10,s:15&biw=974&bih=574
or this: http://www.google.com/imgres?imgurl=http://cr4.globalspec.com/Postimages/200806/plate_8FFEC316-C1AD-E7D4-12F4D8893E3B3351.jpg&imgrefurl=http://cr4.globalspec.com/thread/22534&usg=__xoRIlDqFgJKXrzCEZMK9inJ8mco=&h=400&w=300&sz=43&hl=en&start=60&zoom=0&tbnid=F7ZNda5M1zMivM:&tbnh=124&tbnw=93&ei=kCPCTcHDLMq48gO-0fDMBQ&prev=/search%3Fq%3Dmotor%2Bnameplate%2Band%2Bdiagram%26hl%3Den%26sa%3DG%26biw%3D974%26bih%3D574%26gbv%3D2%26site%3Dsearch%26tbm%3Disch0%2C1486&itbs=1&iact=hc&vpx=658&vpy=339&dur=1287&hovh=124&hovw=93&tx=79&ty=107&page=5&ndsp=16&ved=1t:429,r:3,s:60&biw=974&bih=574
Many times the wiring diagram for the motor is on the motor nameplate. Also, look on the reverse side of the cover for the connection box on the pump motor, as sometimes that's where one will find the wiring diagram for the motor.
Posted on May 05, 2011
SOURCE:
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
Dec 17, 2009 | Crane & Co Crane Plumbing 2386W Oval...
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Just bought a whirlpool dishwasher & unshure how to wire it in ????
There is a connection box at the bottom of the dishwasher that you can run an electric connection to. You will have to get some electrical nuts to connect the wires. The other end of the wire you will have to attach to an existing source (electrical outlet, or directly to a fusebox. You will need to consult some Home wiring books, like from Home Depot or Reader's Digest to make sure you do it exactly right and are in code. Good Luck!
Jul 08, 2008 | Whirlpool Dishwashers
Wiring in a dual fuel range
You must have a terminal block in order to connect the oven cord. May have to buy the part and install it.
Sep 25, 2007 | Thermador PD304BS Dual Fuel (Electric and...
Jacuzzi Submersible Pump, 12 Gpm 3/4 Hp 2 Wire Logo
216 people viewed this question
Top Jacuzzi Garden Experts
john h
Bath and Spa Parts...
Jay Finke
Jay Finke
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
