Darkness in the display, specifically a localized discoloration is a fault in the display/monitor itself. If there was an issue with the motherboard or graphics processor, it would affect the entirety of the display.
The display is obviously still working aside from the dark spot, but this is often an indicator that entire display may soon fail.
Regards,
Dan
IT Professional
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Is it there all the time? Have you turned the computer off and back on? Have you turned the monitor off and back on?
