If u r in Indian then follow the given steps by me
SAMSUNG BSNL 2G AND 3G NET SETTINGS
Listen friends, i know how to connect internet from Samsung s5603, s5350 and many more____
Just follow my simple steps happily--------
Operations to be done in Samsung mobile:
1-
Go to MENU > SETTINGS > APPLICATION SETTINGS >
BROWSER PROFILE > create > write BSNL 3G in place of
connection o1 > write bsnlnet in access name > save it and
set it as default.
Operations to be done in computer:
1- Join your mobile with your computer and run pc studio.
2- Click on widgets in pc studio and don?t touch your mobile as it may be angry.
3- Click on internet connection
4-
Click on add and complete following requirements
connection
name.....................
BSNL 3G
COUNTRY..............................
other
Network
provider........................ other
APN
name..........................
bsnlnet
Phone
no........................ *99**1*1#
5- Click ok.
6- Click yes.
----------A small help to you from -------------aditya dixit, India------email id: [email protected]
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
