The X300 is End Of Life and will not be supported past Windows XP, so NO, you cannot use Windows7 with the X300.The X300 is End Of Life and will not be supported past Windows XP, so NO, you cannot use Windows7 with the X300.
You can't post conmments that contain an email address.
Bootable hard drive utility disk would do that. If your planning on re-installing Windows (any version) the Windows Disk will do this for you, if you are planning on installing a Linux variant the Linux Installer will do this for you.
Hi enoonoo Even though the product claims to be compatible with Windows and Linux, it has 1/ no drivers for any Linux system and 2/ does not work with Vista / Windows 7 . It is useless , it will just don't work anymore . You can always create a network , sharing all machines via a gateway . It also works between different OS versions like sharing a W7 unit with an XP one . Best regards , fanaudi .
Solution: Please change your VGA Card wit Supported Display Card with external VGA, cause if you use for unsupported VGA card the problemsthatwilloccur. I suggest using external VGA (not use onboard VGA) like Nvdia Gforce. I always use that produk for all my Client.
NComputing software updates are only available to
registered NComputing customers. To install the software you must have a
valid NComputing software license and you must read and agree to the
terms in the End User License Agreement and Terms of Use.
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
