You are suffering from a convergence problem. In this case I recommend you see a TV tech. To pull the convergence board is a real chore. Your convergence board will have too many bad grounds to even begin to count. You may not have to replace the convergence IC. The IC will be of a STK-393-110. In many cases this IC will be replaced by an after market part. You will have to check and replace resistors of a 2 watt value of about 3.9 ohms. In good faith, the TV man will replace this convergence IC ,as to try to correct the problem the first time. Good advice for the ,do it your selfer. Take this note to a TV tech. Some knowledge could save you a few bucks. Thanks for asking and show all hands of support!
