Cars & Trucks Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a belt diagram for a 03,f-150 4.2l w/ac
gerry bissi
Level 3:
  • Ford Master 4,390 Answers
  • Posted on May 04, 2011
gerry bissi
Ford Master
Level 3:
Answers
4390
Questions
Helped
3059160
Points
11499
2002 with a/c, best I can do.
Item Part Number Description 1 10344 Generator pulley 2 8678 Belt idler pulley 3 8509 Water pump pulley 4 19D784 A/C clutch pulley 5 3A733 Power steering pump pulley 6 6B321 Crankshaft pulley 7 8678 Belt idler pulley 8 6B209 Drive belt tensioner 9 8620
2answers
I have a 1989 chevy 1500 5.7L the ac is broke and I noticed on the diagram on the fan shroud that there is a diagram for a truck without ac can I just use this belt to bypass the ac
Check to see if the AC belt turns anything else, like Power steering, Alternator, Fan, etc. I had a car with defunct AC once, and took its' belt off (the belt was just for AC) with no problems.
1helpful
2answers
I need a diagram for replaceing the serpentine belt
the diagram should be on a sticker on the radiator shroud cover or, the hood latch cover.
8helpful
I need a belt diagram for a 1997 ford 5.4 without ac
Hello there:
Here are several diagrams for you to choose from itis all for the same vehical but with different options
just click on the diagram that fits your vehical
5080795
Belt Routing Diagram Multiple Accessory, w/o A.C. 5080980
Belt Routing Diagram Multiple Accessory, w/A.C. (98 In. Belt) 5080993
Belt Routing Diagram Multiple Accessory, w/A.C. (99 In. Belt)
4helpful
Serpentine belt diagrams 1991 dodge dynasty
hello there:
Just click on the diagram links beloiw for your model
5060970
Belt Routing Diagram Multiple Accessory, w/o A.C. (Mfg. After 2/27/91) 5060980
Belt Routing Diagram Multiple Accessory, w/A.C. (Mfg. After 2/27/91) 5060990
Belt Routing Diagram Multiple Accessory, w/o A.C. (Mfg. Before 2/27/91) 5061000
Belt Routing Diagram Multiple Accessory, w/A.C. (Mfg. Before 2/27/91)
2answers
Need serpentine belt routing diagram
There are several possible diagrams according to engine and AC. The diagrams are listed below.
#1 with AC
#2 with AC
#3 no AC
13helpful
3answers
Serpentine belt diagram for a 3,3l dodge dynasty with ac
For the 1991 DODGE DYNASTY - V6 3.3L 201ci GAS FI N R , review this informacion:
- Multiple Accessory, w/o A.C. (Mfg. After 2/27/91)
- Multiple Accessory, w/A.C. (Mfg. After 2/27/91)
- Multiple Accessory, w/o A.C. (Mfg. Before 2/27/91)
- Multiple Accessory, w/A.C. (Mfg. Before 2/27/91)
Remove the serpentine belt by using a breakover bar, rachet or serpentine belt removal tool with the correct size socket for the pulley mounting bolt. Rotate tensioner arm to release tension. Remove the belt.
Hope helped with this (remember rated this help) Good luck.
1helpful
Need belt alignment
You didn't specify if the car had AC so I've attached 2 diagrams, the 1st is without AC, the second diagram is with AC. Best of luck with your repair and thank you for using Fixya!
Greg
1helpful
3answers
I neeD A SEPRPENTINE belt diagram for a 2000 golf 2.0L
2000 Volkswagen Golf 4-Cyl. 2.0 L
Serpentine - Alt. & W.P.; W/O A.C.; W/O Dual Sided V-Ribbed Belt
Serpentine - Alt. & A.C.; W/O Dual Sided V-Ribbed Belt
Serpentine; W/A.C.; W/Dual Sided V-Ribbed Belt
I hope help you with this (remember rated this help) Good luck.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
