Hi if you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
PUK CODE FOR YOU SIM CARD MUST BE GIVE YOU A SERVICE PROVIDER AT&T, VERIZON, T-MOBIL. IF YOU CANT USE YOU CELL PHONE WITH ANNY SIM CARD YOU MUST BE RESTORED.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Hi bro , PIN CODE:U can get the pin code from the service provider . he will give u some default pin . If all ur entries have proved to b a failure then it will ask for PUK no PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.U can also get it from the nearest service provider . NOTE: You should ask your service provider,get the PUK,if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM For any quires write back to me .
Hi,if its a 4 digit code, it must be PIN number, PIN CODE is SIM dependenet and not phone dependent
If you forget the PIN enter wrong PIn to get PUK to folow these procedure
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times, This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
you can get the puk code from your service provider, whomever that may be, vodaphone, O2 orange etc... they will ask you for youe IMEI number inside the phone (probably under the battery), then they will issue you with a puk code.
puk code can be used onnly if u hav tried using ur pin wrongly more than 3 times so try remembering the pin else try it 3 times if its right no problem if not after 3 times it wil ask puk code at tat time use it phone wil be unlocked
another solution is cal ur AT&T they also hav pin no get it from them
