I don't think it's dripping down,you have a blocked drain,if you follow the back wall down to the bottom you'll see a drain hole,when the freezer goes into defrost the heater comes on and melts the ice off of the evap coil,the water suppose to drain down the hole into the pan at the bottom of the machine where it will evaporate but it sounds like your drain hole is blocked.it's a common thing with all machines,unplug it,melt all the ice with a hair dryer and melt out the ice in the hole,now you have to clean out the line,i have a steemer to blow out the line,if you don't have a steemer you need something that will blow through like a turkey baster or if you have a shop vac you can vac out the hole then put the vac on blow and blow through the hole,when you think it might be clear pour hot water into the hole,if it drains you're all done,if the water doesn't drain down you have to keep hitting it,if you try to snake something down the hole be careful most of the lines are plastic and you don't want to poke a hole through the line.if you can't see the drain hole on some models you have to remove the back inside wall of the freezer but it sounds like this is your problem.good luck and if you need a hand with anything else i'd be happy to help.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Silicone bath/shower sealant should work, the one that smells like vinegar. Also known as RTV.
Just make sure the area is dry, clean and free of old caulk.
It'll need to be at room temperature to set properly for a few hours.
I have used this sealant on things before that went as low as
-50C. Preperation is the key though.
