Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
SOURCE: I need to reprogramm our
Take a look at the User Guide (available for download at this link:)
http://www.phone-manuals.com/panasonic/KX-T7433.shtml
to see if you can find what you need.
SOURCE: I'm installing a Panasonic 616
There are 3 versions of the software for the KX-T61610 system, and also a KXT-616D box. The nameplate of the 10 has a revision number in a circle, or not, which would be either circle 2 or circle 3. Since program 03 was deleted (Connect/No Connect) in 3, I'm guessing that's what you have.
Unfortunately, they issued a basic manual and addendums and you have to know which one you have in order to program the box. Your PROGRAM button on the back of a phone doesn't do anything in this case, just the SET/PROGRAM switch on the cabinet. When you set it to PROG, the phone will say Sys Prog ? or something similar. Here's a link to circle 3 software. You'll know even if the plate doesn't have circle 3 because it has a program 44. Also, your 03 program is Console/Telephone for pairing a DSS console to an extension....really useful if you have a 7040 unit :-) http://www.public.carl.airpost.net/Pana/KXT-Analog/t61610B_inst.pdf
Please note that there's a FOURTH programming guide, and this is it. The codes and description should be similar, but this is for a European system and there was no doorphone control and they had internal music. The companion R3 codes are found here http://public.carl.airpost.net/Pana/KXT-Analog/R3_program_codes.pdf
Anyway, to ease your Connect/No Connect issue, you program out the vacant lines in 07 and 08.
Hey, I told you it wasn't going to be easy :-)
Carl
SOURCE: Dear Expert, i need the manual
Here is the link to your manual.
http://www.user-guides.co.uk/download/free/freedownload/free-download-panasonic-kx-t7230x-manual.html
SOURCE: panasonic 308 easa-phone manual
It is one of these two links, not sure which
http://service.us.panasonic.com/OPERMANPDF/KXTA308.PDF
http://service.us.panasonic.com/OPERMANPDF/KXTD308.PDF
I hope I have been of help but please do not hesitate to ask if you have any further questions.
