SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
SOURCE: I have plantronic headset model CS55 the green light is blinking
Either the battery is low, or the unit is switched on. If you're looking at the base unit of the CS55, on the right hand side there is a switch that either points to I or II. If it's on II, your headset will be activated the second it is removed from the base. If it's on I, it won't turn on, thus it won't turn the light on. Check to make sure that dial is on I instead of II, and when you pick it up you shouldn't have that problem anymore.
If it's a problem with low battery you have to make sure that when you place the headset on the charging cradle that it's securely seated in there. Also make sure that you clean the charging contacts (the brass-coloured contacts on the headset and on the base) about once a month with rubbing alcohol.
SOURCE: phone doesn't ring in earpiece
Only if you have an HL-10 lifter installed... you will then be able to hear three short beeps in your ear to indicate the phone is ringing.
SOURCE: plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being
set too high.
1. First, try lowering the volume of the telephone. If you
still hear an echo, adjust the volume of the headset itself.
2. The master
transmit controls of the headset are the ABCD switch settings on the
bottom of the base. A is the lowest and D is the highest setting.
3. You
can fine tune this setting with the plus (+) and minus (-) buttons on
the back of the charging base.
4. If this doesn't fix the echo, try moving
the configuration dial on the left side of the charging base. The
recommended setting for most phones is 1.
SOURCE: outside caller hears themselves in an echo
set too high.
2. The master
3. You
