Motorola Mobility W755 (4 GB) Cell Phone Logo
Posted on May 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i adjust the volume on my phone, not ringer, but voice volume?
David Bukovaz
Level 2:
New Friend:
  • Expert 144 Answers
  • Posted on May 03, 2011
David Bukovaz
Expert
Level 2:
New Friend:
Answers
144
Questions
0
Helped
24908
Points
434
While you're in the middle of a call use the same button to adjust the ringer volume. It should only adjust the in call volume.
How to turn ringer volume down on my phone
When the phone is waiting for a call, the same volume button for voice will raise the ringer volume.
5helpful
Increasse Panasonic telephone volume
You may download a copy of the manual here. To adjust the ringer volume, see the instructions on page 37. To adjust the voice volume during a call, press up/down-arrow.
I can't hear peoples voices when they call. The volume only works for the ringer
If you want to change volume of the caller's voice, then try adjusting the volume control WHILE you are actually talking on the phone during a call.
If you try to adjust the volume when there is no call in progress, then the volume controls will only change the ringer volume.
If you provide the exact model number of your particular device, then we may also be able to provide you with the User's Manual for your phone.
I hope that was helpful Loli.
Good luck and take care.
Joe.
2answers
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
1helpful
How do i adjust voice volume on my jitterbug
The rubber volume button on the outside of the phone adjusts both the ringer volume and the call volume, which is how loud a caller sounds when on a call. If you are not on a call, the volume button will adjust the ringer volume. To adjust the volume of a caller, you must adjust the volume while on that call.
To do this, while looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the call volume level. You may also set the call on Speakerphone mode. If you have the Jitterbug J model, there should be a button labelled "SPKR" on the upper left corner of the keypad.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
1helpful
How to increase volume for nokia 6300
hi...
1.You have a side key for adjusting the volume of voice when on call.
top key for increasing the volume and lower one for decreasing
2.you want the ringer volume to increase please follow the steps
1.open MENU
2.Go to profile
3.Go to personalise
4.there is a option called as ringer volume.
5.increase and decrease the volume in it.
6.Save the changes
Thanx
1helpful
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
2helpful
When someone calls me the ringer on the phone does not ring.I do not know how to turn the ringer back on. Also when someone tries to leave me a message the answering machine does not record the message....
On the phone not ringing, just push the volume up button while the phone is not in use, that should adjust the ringer volume. As for the message saying that calls are being routed to an automatic message sertvice, that sounds like a voice mail offering from your service provider, not the phone. Uniden phones have a default greeting that says "Hello, no one is availible to take your call, please leave a message after the tone" Contact your service provider and find out if you have voice mail service on your line. If you do and want to use the answering machine on your phone, you will need the service provider to allow for more rings before the voice mail service takes the call.
10helpful
2answers
Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
