Sewing Machines Logo
Posted on May 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where there was an oil hole. Then I put in new needle. Fly wheel was had to turn, but machine sewed. Today the same thing happened with a loud knocking and when I would start to sew it made a popping noise. now it won't sew, and flywheel is hard to turn. Also when I take my foot off sewing pedal it will take an extra few stitches before it stops. Thanks for any help or advice Patricia
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on May 04, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
31880
Points
167
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
Testimonial: "Thank you so much for your advice. I am taking to repair shop this week. It is a great machine. Thanks again~~Patricia~~"
1helpful
Janome Magnolia 7318 suddenly started making a lot of noise, sews a couple stitches then jams, bobbin thread tangles. It is clean, no lint or thread anywhere in the undercarriage.
Remove all the thread. Install a new needle. RAISE the presser foot and rethread from the beginning. Confirm it follows the correct thread path and the upper tension is set at the midway point.
If that doesn't resolve the issue, you may need to take it for service.
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail......
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
Machine eats bobbin thread
computerized so could be anything
tension or sewing action parts needs a service
3helpful
Needle screw won't stay tight and needle comes out
the screw & the needle clamp may have to be replaced
Blind Hem Stitch jamming
have you changed the needle lately?
have you tried rethreading the machine?
when was the last time it was serviced?
1helpful
2answers
I need instruction manual for Magnolia 7318
Janome Magnolia 7318 (Sewing-Quilting Machine) user manual, guides and product documentations.
http://janome.imvoi.com/sewing-quilting-machine/magnolia-7318.html
Look under available documents and click on "Janome Magnolia 7318 User Manual".
This opens the user manual in PDF format.
You can save the PDF to your local computer to refer to any time without going online.
I have a Janome Magnolia 7330. The bobbin thread will not be drawn up.
The easiest solution would be to change your needle. They do wear out, get bent, etc, and that makes it difficult for them to pick up the bobbin thread. If you did just change the needle, there was a hint here on FixYa about being sure to face the needle correctly. If you feel the needle, there will be a flat side and a curved side. Check your owner's manual to see which side should face which direction.
2answers
Need the tension settings for a Magnolis 7034D machine. Kids turned them all.
Hi
There are a partial manuals available for Janome Magnolia machines available on their site.
http://www.janome.com/documents/File/ManualFile/Inst%20Book%207034D%20(English).pdf
The tension settings are included on page 27 of the manual.
Hope this helps!
1helpful
2answers
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
