I have been trying to uninstall printmaster and even after following the directions it will not uninstall. The install shield comes up and then it aborts.
If you are unable to get your PrintMaster 2020 software to work on your computer, there could be a few potential causes for this issue. Here are a few things you can try:
Check the system requirements: Make sure that your computer meets the system requirements for the PrintMaster 2020 software. If the software is not compatible with your operating system or hardware, it may not work correctly.
Check for updates: It is possible that there is a newer version of the PrintMaster 2020 software available that is compatible with your computer. You can check for updates by visiting the manufacturer's website or checking for updates through the software itself.
Reinstall the software: If the software is installed but not working, you may need to uninstall and reinstall it. To do this, you can follow these steps:
Open the "Control Panel" and go to the "Programs" section.
Click on the "Uninstall a Program" option.
Locate the PrintMaster 2020 software in the list of installed programs and click on it.
Click on the "Uninstall" button to uninstall the software.
Restart your computer.
Download and install the latest version of the software from the manufacturer's website.
Check for other issues: If you have tried the above steps and the software is still not working, there may be other issues causing the problem. These could include problems with the software itself, conflicts with other programs on your computer, or hardware issues. In this case, you may need to seek further assistance from the manufacturer or a technical support professional.
Here is a link to their website which describes how to manually remove the software from the hard drive. Let me know if it doesn't work and we can try some other options.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
Make sure you can see all the files. (My computer --> Tools --> Folder Options ---> View (tab) --> <Select 'Show hidden files ...' option.
Find the folder you have indicated.
C:\DOCUME~1\Jan\LOCALS~1\Temp\{A35C2323-3CEA-405C-9569-EF5DDE930B2F} Delete that flder. Restart the computer and reinstall the software.
your computer is being a pig. dont worry about uninstalling your printer, just add another printer and make this one the default printer. you can just ignore the other one...........shimple.
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Uninstall everything by using any unistaller software like ashampoo, after that reinstall printmaster platinum without any applications running on the background
