If this is a Sylvania Netbook running Win CE 6 it is possible that the operating system simply doesn't have a driver for Virgin Mobile cellphone.
The only way I have been able to connect to the internet is via Wifi or a LAN cable plugged into the back. I doubt you will get any other method to work.
Please note the Wifi can be via a Wifi access point on your cellphone, a portable, mobile hotspot that connects via a USB modem or any other functional Wifi access point.
Tom M.
Flip the machine over and find a small hole about 1in. diagonally from the right lower corner of the data plate. Insert the tip of a tooth pick into the hole and press down for about 10 second, with the AC power connected to the machine. It should re-load a fresh copy of the operating system
