The error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
Hello sir, When the Canon IR 3300 switchs on it displays the Error code E000012-0002 please help me what to do
SOURCE: canon ir 3100 error code e000070-0001
the error code appeared because a tension arm (front or rear) of the ITB tension roller was broken. check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
SOURCE: my canon IR 3100 CN
E004
The main thermistor (TH1) has an open circuit or has poor contact. The sub thermistor (TH2) has an open circuit or
has poor contact. The thermal switch (TGP1) has an open circuit. The main heater (H1)/sub heater (H2) has an open
circuit. The AC driver PCB is faulty. The DC controller PCB is faulty.
E004 0001 protection circuit error of the fixing unit
Description: A short-circuit is detected in the triac (for 1 sec or more continuously) while the heater remains off (hardware detection) for 40 msec continuously.
Remedy: Turn off and then on the main power supply.
Remarks: fixing assembly triac malfunction/13V power supply error
