Try the following, (may work)
To manually select the network operator to use for data connections
You can also manually select your network operator from Connection Setup's
settings screen. Connection Setup will then reconfigure your device's data
connections settings based on the operator that you selected.
1. On the Home screen, slide to the Settings tab and then tap All Settings.
2. On the Connections tab, tap Connection Setup.
3. Select the network Country and Operator you want to use, then tap OK.
Note If you choose a Country and/or Operator that is different from the installed SIM
card network operator, you may not be able to access network services.
4. When prompted to confirm whether you want to configure the data
connection settings based on the selected network, tap Yes.
Connection Setup configures the data connection settings.
5. After the Connection Setup completes the configuration, tap Restart.
