Keurig Elite B40 Coffee Maker Logo
A
Anonymous Posted on May 03, 2011
Our Keurig Elite B40 has been leaking water at the base for several months now. Can we fix this?
  • Anonymous Mar 22, 2014
    Leaking out base
Anonymous
Level 3:
  • Keurig Master 43,501 Answers
  • Posted on Sep 05, 2011
Anonymous
Keurig Master
Level 3:
Answers
43501
Questions
0
Helped
10835405
Points
101584
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Water won't drain on single brewer keurig when iput the handle down
Contact 1-866-901-2739 for factory service assistance as they can run you through several scenarios to fix the problem.
Keurig is leaking out the back along bottom
Seal is damaged and needs replacement. Factory will di free under warranty.
1helpful
All of a sudden my mom's Keuring B40 won't make a full cup of coffee.
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
