Please check the link below for the HP driver downloads:
HP 1220 deskjet
Http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=se&prodNameId=19142&prodTypeId=18972&prodSeriesId=25521&swLang=8&taskId=135&swEnvOID=4062
This is where to go for the automatic download of your drivers, otherwise I would try downloading the older drivers (vista or xp) and run the driver install software in compatibilty mode. (right click the setup file and select troubleshoot compatibility, you will then be presented with a selection of tick boxes, I usually select the "worked in earlier versions" and "Requires extra permissions" options. In the next box, select the operating system required for your drivers and click next. Then click "run the program" and follow the install instructions.
Hi, you can download the driver here at HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=19142&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25521
Remember to select windows 7, 32 or 64 bit system.
Or use the windows update function.
The printer has to be connected with the usb cable
and has to be turned on.
Hope this will help you.
