Canon FAX-L800 Plain Paper Laser Logo
Posted on May 03, 2011
My fax model is L-800, and is not receiving or sending faxes.the memory LED is on and green in colour. what could be the problem?
targetchip
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on May 03, 2011
targetchip
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
7922
Points
75
Have you tested the telephone line to see if it has dial tone. Unplug the fax from the line and plug in a analogue phone to test this.While you are there check the extension number with the phone to make sure you are still on the same number. You can do this by dialing any phone with a display ie a mobile.
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
Receiving fax with a black wide (2") line from fax Brother Intellifax 4100
its the problem of your LED'S strip may be one of the LED is not working.It lights up green in color & its located under the top cover from where you send fax copy.
Please rate me if it was helpfull..
Received faxes, cartridge has run out how can I print or send to PC
some new fax machines has, fax memory older models dont, so if your fax machine is old. the fax has been lost, because when printing is one time (dont preserve on fax memory, only the comunication numbers. try talk to your fax senders send again a fax copy,
2helpful
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
1helpful
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
1helpful
Cannot get messages out of memory
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Canon Laser Class 7000 H12013 - need user manual - 'received in memory' on display
we have this machine! all you have to do is hit the green button and they will print out!
1helpful
2answers
Dx 800 fax machine
Only one sender, or all sender's?
Unplug the machine and replug. If it has an OUT button, make sure it's lit.
When all else fails...
Unplug machine
Hold down energy saver key
plug in
scroll down to SHIPMENT SET
press set
set
wait for reboot
old marine
old marine
ZJ Limited
ZJ Limited
