First off, if your dimmer is getting hot, then there is something wrong. This is dangerous. Do not leave that dimmer in the wall. Remove it.
1) A typical wall switch controls up to 1400 Watts. Look at the watt rating of your dimmer. A 600 watt dimmer will control up to 600 watts. If you have 600 watts on your dimmer, expect a shortened lifespan for that device. If you have more than 600 Watts, expect overheating and possible fire.
2) Lutron makes 1000 Watt dimmers
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch3) Type of bulb: Review the specs shown on link above because they show wattage, and they also show which light the dimmer is made to control
4) If your lights are on a 3-way switch, then dimmer has 3 screws and connects to 3 wires. If your wiring is incorrect, it might give symptoms shown above.
If your switch had 2 wires and you put those wires on a dimmer with 3 screws, it might be wired incorrectly.
Check wiring. Re-post a question if your are confused about details.
5) There might be a short in the circuit ... or in the dimmer ... replace dimmer with another one from Home Depot and see if symptoms persist. Disconnect ground wire as a test only and see if symptoms disappear ... if so then there is a short somewhere in the circuit
Don't burn the house down.
