If you purchased this computer new ... return it and have the retailer make it right. If this is a previouisly owned computer, it might be worth the $75.00 to have the big box store take a look at it.
Testimonial: "It was purchased new. Thanks!"
Since it is new ... it has a warranty ... and the retailer and the manufacturer have a responsibility, a duty to give you what you paid for. If you mess with it ... you will be relieving them of their responsibility. Make sense? Thanks for your speedy response and 4 thumbs up evaluation.
More than likely you have been loaded down with alot of useless software upon bootup.
If is windows 7 hit start button then type msconfig click selective startup then the startup tab and look for any programs that may be running that you dont need on startup. Things like google updater or imaging software basically any program that you know loads upon startup that you dont use. De-select the ones you dont need apply and restart should speed up quite a bit.
Scan Laptop for Viruses Laptop runs slow issue may appear if the
system is infected by some malicious application. You have to search
and remove that application from your system. For your convenience
download and install a powerful antivirus program. Run a complete PC
scan to detect viruses and remove them from your system. Note: Close all other programs before start scanning your system. Run Check Disk Errors in the operating system may
result in laptop runs slow problem. To remove errors you need to run
check disk. To do so follow the steps below: Stop Unnecessary Background Programs Sometimes there are some background
programs that are running without our consent and eating up the memory
and energy of the CPU. Closing down these programs will speed up your
laptop performance. To do so follow the instructions below: Run Disk Cleanup Efficiency of laptop decreases when it
contains too many junk files. To clean junk content from your system
follow the steps below: Fix Registry Errors Mostly laptop runs slow issue occurs due
to broken Windows registry entries. Fixing registry will help you to
boost up your laptop. You need to download and install a Registry
Cleaner program to fix corrupt or broken registry entries. To download a
reliable Registry Cleaner tool click here.
