AC
The E1 or E2 error code is an Auto-Stop Protection Error, indicating an issue detected by a sensor. This error code will require service. The E3 error code displays when an Abnormal Operation Protection Error has occurred, and activates to protect the unit from damage. This error code will require service.Dec 20, 2018 https://www.lg.com/us/support/help-library/e1-e2-or-e3-error-code-CT10000014-1340721215523
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
F1 - E0 EEPROM communication error F1 - E1 EEPROM checksum error F1 - E2 UL A/D error F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match stored value F2 - E0 Shorted touch pad F2 - E1 Keypad cable connection error F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models) F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models) F3 - E2 Oven temperature is too high (Cook mode) F3 - E3 Oven temperature is too high (Clean mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models) F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models) F3 - E6 Drawer sensor open F3 - E7 Warming drawer sensor shorted F4 - E1 Meat probe malfunction - shorted F5 - E0 Door Switch F5 - E1 Self clean latch will not lock F5 - E2 Latch during CLEAN error F5 - E5 Self clean temperature not reached within 45 minutes. F5 - E6 Door is open, but latch is locked F5 - E7 Self clean latch will not unlock F6 - E0 Return line not connected F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure F1 ERC Board failure F2 Oven temperature is too high F3 Oven temperature sensor open F4 Oven temperature sensor shorted F5 ERC Board failure F7 Function key stuck on ERC F8 ERC Board failure F9 Oven door lock failure
If you get an error code, try first resetting the code: 1. Disconnect power for about two minutes. 2. Connect back power. 3. If code re-appears, test and eventually replace faulty part.
support-us.samsung.com/.../pop_troubleshooting_fr... Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08 Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
