Garden Logo
Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is a gas and oil mix required for homelite bandit chain saw 33 cc. if so how much. just got it from a pawn shop
Anonymous
Level 2:
Scholar:
  • Expert 147 Answers
  • Posted on May 03, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
147
Questions
0
Helped
27998
Points
355
Yes! Normally 32:1 gas oil mixture is what you will need. The easiest way is to buy the oil in pre-measured bottles (Usually available in 6 packs). That way all you have to do is add one bottle per one gallon of gas.
Hope this helps.
(Don't forget bar oil)
Testimonial: "thank you much for your fast response. it was very helpful "
What is gas oil mixture for a Homelite 33 cc Ranger?
50:1--( 50 parts fuel to 1 part oil)
Now you can buy a special oil from Stihl service agents that has a 50:1 formulation that will cover all mix ratios regardless of the engine make or ratio requirement
saves having different tins for different ratios for different engines
What oil to gas ratio
Most newer chainsaws and small 2 stroke gas gardening tools use a 50:1 older chain saws use 40:1. If you don't know just use 40:1 your saw will only smoke a bite. Use hi test gas and good quality oil
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Need fuel mixture specs
50:1 is the fuel to oil ratio using a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to mix the fuel and oil in it's own container, and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
5helpful
2answers
Just got a homelite 33cc 14 inch chain saw, do you mix gas and oil on this chain saw?
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
3helpful
Correct mix of gas and oil for Chain Saw
The ratio is 40:1, provided this is a gasoline homelite chainsaw. Find the suitable amount to put into the gas can at a ratio of 3.2 oz per gallon. The bottles that you buy the oil in have marks on them telling you how much there is, and often times, are sized to dump into a preset amount of gas. Put the oil in the can, then put the gas in the can, cap, and shake. Always shake before dispensing.
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
