SOURCE: putting back together the logitech extreme 3D pro
it was junk anyway, after about a year or two of service the spring will wear and you will have to send it into logitech, if they cant fix it they will then ask if you want a refund, i would say yes and just apply that money towards a new joystick. My friend had the same joystick and it wore out after two years. he disassembled it, and tried to fix the problem, then he reassembled it and then it didnt work period although everything was ok, so he just tossed it in the trash and bought another one.
SOURCE: Logitech Extreme 3d Pro Calibration problems.
Hello There,
Also dont' I meant NO, Do NOT install the software that came with the joystick, it lure a lot problems on calibating and others.
use the game control panel on windows instead.
good Luck
SOURCE: twist handle on logitech extreme
Hi Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, then click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts...... Please check the bellow links to read the article for the tutorial:- http://forums.bf2s.com/viewtopic.php?id=81419 Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok".
