I bought a new wii fitt balance battery pack. I plugged the battery pack into the wii via usb.Tthe light on the charger turns from red to bleu (Not blinking) and after 12 hours it stils hasn't charged the battery. The light is stil Blue. I can't play on balance board even when its synchronized. What's wrong?
Make sure that when charging the battery pack it must be attached to a
wii-mote otherwise this may cause a flashing red light.
If the battery pack is attached to the wii-mote and you still have a flashing red light this may indicate that there could a problem with the battery pack itself.
you do have rechargeable remotes right? And the light only goes to red if you are not connected to the internet or were connected but unplugged it. i use a store bought charger that came with a rechargeable battery panel that plugs into the remote. so if i take the battery cover off the batteries are attached to it. but that is just me i don't know about you. hope i helped. If i didn't, post a new problem that tells the steps that you take to try to charge them.
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
You may want to send an email to [email protected]. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Insert a Wii Balance Board compatible game disc in the Wii console.
Use
the Wii Remote to select the Disc Channel from the Wii Menu, then
select "Start" to begin the game. Press the A Button to bypass the
wrist strap screen.
Open the small SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
The blue light will stop blinking and stay on steady once the syncronization is complete.
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
