Toredo tunneling adapters are the basis for VPN tunnels; built around the VPN standards introduced into very early versions of windows.
Windows NT and 2000 infact; used a central 'stack' to handle dial up connections; XP still uses it and Windows 7 emulates it... so these technologies are still true in todays world. It's all part of RASDIAL..
http://support.microsoft.com/kb/163111
Unfortunately ERROR CODE 10; is not a RASDIAL error code.. so we are going to need more information.
can you supply us with more info?
1. Open command prompt with administrator credentials (Find CMD and right-click - Run as Administrator).
2. Enter netsh environment. Type "netsh" and ENTER.
3. "int teredo" and ENTER
4. "set state disabled" and ENTER.
5. Open Device Manager and uninstall "Teredo Tunneling Pseudo-Interface".
6. Open command prompt with administrator credentials once again.
7. netsh + ENTER.
8. "int ipv6" + ENTER
9. "set teredo client" + ENTER
10. Open Device Manager and Scan for new hardware.
11. Select "Show hidden devices" from the View menu. You will now see that it is present without errors with any luck.
hope this helps
