Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to hook up a turntable to a pioneer vsx-1019
alexander woolfolk
Level 2:
Guru:
  • Expert 276 Answers
  • Posted on May 02, 2011
alexander woolfolk
Expert
Level 2:
Guru:
Answers
276
Questions
Helped
110173
Points
753
Receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
2helpful
2answers
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Can't hook up my turntable to my pioneer reciever VSX-519V,I see no hook-up for it!
You need to have a turntable with a built-in preamp. The receiver does not have a phono preamp in it like the older receivers did.
10helpful
2answers
Flashing Red MCACC Light
hold the tune down (-) button and multi zone on/off button for two seconds then receiver should reset on the VSX-1019AHK model!!!
12helpful
5answers
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Recently purchased this reciever, and in reading the manual, I cannot tell if it will work if I hook my Comcast HDMI to one of the HDMI inputs (Input 2)? In general, i will be only hooking up the Cable box...
It should work fine. The Pioneer VSX 1019 AH-K has been made so that it can accept 4 HDMI inputs (of which 3 are assignable, and 1 is for the BD player)
If you still have a problem, you can resort to the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. A lot of helpful guys out there, and a very active thread.
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
1helpful
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
 Grubhead
Grubhead
SmartAviator
SmartAviator
