In order to split music on your iPod by genre, you must connect it to your computer and have iTunes installed. iTunes lets you organize music in a variety of ways including by genre. Create a playlist on iTunes by clicking the "New" button and typing a name for it. From there, simply drag and drop songs and organize them by genre.
You can add genre information to music and then you can split music by genre with ease. Just follow below steps.
It is sensible for you to use Leawo Tunes Cleaner to help you to find genre in iTunes. This application can organize iTunes music library well, which has been introduced in the first part in brief. Now let's begin to see how to use this excellent iTunes manager to get back your genre info of music in iTunes.
Step 1: Select "Start to Clean iTunes"
Run Leawo Tunes Cleaner on your computer and then click on"Start to Clean iTunes" option in the main window. Then this iTunes genre finder will begin to scan your iTunes music library automatically.
Step 2: Fix iTunes Music Library
When the scanning process comes to an end, this iTunes clean-up tool will show all music files that calls for repairing in 4 different categories. Thus, you can hit on the button of "Fix All" at the top right corner of the interface to begin to fix iTunes music library. It will become "Pause" button after you click on it.
Step 3: Manually Edit Songs Info
After the automatic fixing procedure, if you still would like to adjust the music genre info manually, you can click on the edit button in the framework of each music item to call out the editing panel of the song. After you alter the song info manually, you can click on "Apply" button to apply the fixed results to your iTunes music library.
The automatic fixing process is quite fast and the manual editing feature of this software is quite friendly. You can download this software and have a try in case you need.
For more methods, check: Best 5 iTunes Genre Finders
