Black & Decker DCM100 12-Cup Coffee Maker Logo
Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My coffer maker brew basket keeps overflowing. I've deduced that when I push my decanter into the machine, there is so much give that the plastic arm in back pushes it forward and stops the coffee from flowing, thus making an overflow. Help? How can I fix this? I've only had it for 2 months!
Jean DeLauche
Level 3:
  • Black & Decker Master 2,911 Answers
  • Posted on Feb 04, 2018
Jean DeLauche
Level 3:
Answers
2911
Questions
Helped
975680
Points
13030
Hello, Srober48 -
Since your Black & Decker coffee maker is only a few months old, it is most likely still covered by warranty.
I suggest you call the Black & Decker Customer Service / Support telephone number printed in your owner's manual / instructions and find out if you can take the coffee maker to an authorized repair center (for free, warranty-covered repair) or if the company will provide you with a replacement coffee maker.
Note: I suggest you do not try to repair the coffee maker yourself while it is still covered by the warranty.
Best wishes.
2 Related Answers
Jack Reed
  • 30 Answers
  • Posted on Oct 24, 2008
SOURCE: Spacemaker? Digital Coffeemaker-overflows during brewing with grounds everywhere.
I've read of this problem from other users of the newer Spacemakers and believe I know what's going on. Black & Decker used too strong a spring in the mechanisms involved in the "sneak a cup" feature which keeps the small tab or finger underneath the basket from opening and allowing the coffee to run into the decanter.
My suggestion would be to make certain that the tab that presses against the bottom of the basket is open when you insert the carafe. Not owning one of these units I can't state categorically that this will solve your problem, but all of the Spacemakers are fundamentally the same, just some cosmetic and design differences between them.
If it turns out that the tab is open when you go to bed and the basket still overflows it's possible the spring is so strong that it's moving the carafe away from the back of the unit, causing the tab to close against the basket. If that's the case I would figure out how to remove the spring without breaking anything in the process, then take it down to your local Ace Hardware and get a same sized but weaker spring. That should solve the problem permanently.
Anonymous
  • 46 Answers
  • Posted on Jun 16, 2009
SOURCE: Water and coffee spilling from Filter Basket onto counter?
We used to have the same problem! try a better brand of coffee filter! It worked for us? Also make sure that the filters are not doubled up!
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Just bought a Bunn coffee maker at a garage sale great condition how do you make the coffee I have poured water in turned the side switch on and the warmer switch yet nothing?????
The machine requires an initial set up to be completed before using it. Fill the decanter with cold water and close the lid. It will take 3 minutes to partially fill the water tank in the back. Then fill the decanter again with cold water and pour in and close the lid. Then plug in the machine and turn the vacation switch on the side of the machine on. After 15 minutes, you will be ready to brew coffee. Then you will get your filter basket ready with the filter and grounds. Pour in from 4-10 cups of water and place the decanter on the base. Close the lid and the coffee will begin to brew. If you will call customer service with the model and date code, a use and care manual can be sent out to you at no cost.
The coffee maker over flows with coffee
You might have to reprogram the brew level. Does it over fill the decanter or is is over flowing from the brew basket?
If from the decanter then reprogram, there are instructions behind the front panel.
If from the brew basket then adjust coffee grind and or volume, also check and clean the sprayhead.
Sometimes coffee maker overflows
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
1helpful
2answers
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
2helpful
Water overflow
If the water is running out the seams in the plastic BEFORE you brew anything, it is a defect or design flaw. I bought one that looks like the one pictured and it did the same thing. So did the replacement.
If the overflow occurs during brewing, verify the following:
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
3helpful
1helpful
4answers
Grounds overflowing
Iam useing the right filter.
Top Black & Decker Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
