SOURCE: motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
[email protected]
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
SOURCE: Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
SOURCE: ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
SOURCE: Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Testimonial: "Thanks. Printing out the settings helped me realize it was not a printer issue. It was a software issue. Installing older version of software fixed it"
