Physical switch
Locate the switch on the top of the keyboard just below the LED light and above the HP quick access keys.
Press the button once.
Wait for the light to turn blue to be sure the wireless network is activated.
If don't work try:
Go to the "Start" menu and press "Run."
Type "netcpl.cpl' in the "Run" field and press "Enter."
Right click on the "Wireless Network Connection" icon and select "Enable."
To turn the wireless on on your laptop:
1. Click on Start. Type Mobility in the Search box. Hit the enter key.
2. In the Search results under Programs you will see Windows Mobility Center. Click on it to open it.
3. You will see a button under "Turn Wireless On"
4. Click on it to enable your wireless.
Another way using a keyboard shortcut: Press the fn and F2 keys at the same time.
I hope this helps you-Thanks for using Fix Ya.
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
