Sport & Outdoor - Others Logo
Posted on May 02, 2011
I want the Garmin 300C Fishfinder pin out wiring for the depth transducer.
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Jul 26, 2008
SOURCE: Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Anonymous
  • Posted on Apr 07, 2009
SOURCE: Garmin Fishfinder 160 will not display bottom
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
Anonymous
  • Posted on Aug 31, 2009
SOURCE: Mounting a transducer on a canoe
I used a suction cup with a bracket to attach the transducer.The suction cup is attached to a rope and when landing just pull.
Anonymous
  • 10865 Answers
  • Posted on Nov 20, 2009
SOURCE: my fishfinder will not continue
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
budgie140
Ian Summerfield
  • 502 Answers
  • Posted on Jul 08, 2010
SOURCE: Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Garmin 300c fishfinder will go from correct depth to 0.0 ft while traveling.Have to turn it off and restart. It is on Hurricane deck boat 198. It is located between engine and leveling tabs.
My experience as a user is that turbulence around the transducer can cause mine to flash and the depth to remain static.Is your fault affected by speed? Sounds to me that you have a faulty connection causing the transducer to "not register". I'd check connections and also the integrity of the transducer. Hope that helps...
Best of luck
My Fishfinder 300C suddeny does not detect the depht anymore, all oher function are still working, please help!
Hello
First do this. From the Home screen, Seelct Full Screen > Menu > range. Use ROCKER to set the depth scale, and see whether the depth is displayed or not. If not check the transducer for fault. Check for voltage goint to it.
Use a test light or voltmeter to determine the polarity of the voltage source.
Connect the red (+ or positive) wire to the positive voltage terminal.
If you use the fuse block on the boat, route the positive connection
through the fuse
Connect the black (- or ground) wire to the negative voltage terminal.
Install or check the 3A fuse (on the fuse block or in the in-line holder).
Align the notches on the cable plug and on the back of the Fishfinder 300C. Insert the cable into the connector, and turn the locking ring
counter-clockwise until it stops.
If htese all are correct and voltage is there at the tranducer end, the tranducer is faulty, and should be replaced. OK
Jul 25, 2011 • GPS
1helpful
I recently charged my battery and since hooking it back up to my fishfinder it constantly says supply voltage too high transducer turning off. ive tested the battery and its perfectly fine.
Maximum voltage for that unit is 33V. Test the voltage with a multimeter at the fuse block or as close to the unit as you can. If you are reading less than 33 volts than your voltage input is fine and you need to contact garmin for a repair or replacement if your unit is still under warranty.
Also check your connections at the battery; make sure everything is clean and that you do not have any + and - wires switched.
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
1helpful
2answers
Garmin Fishfinder 160 will not display bottom contours and does not display depth continuously.
Good luck
Willem
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
