This could be caused by a few things. Make sure your cable it plugged into the Router and the Network on your computer. Also make sure there is a green light on the Router and your Network card, if not you might have a bad cable. Swap out your cable first to ensure the simplest fix is tried first. Also try another network plug on the router (If you only have one plug, go to the next step)
If your still having issues, try to replace the network card on your computer, this is probably going to cost around $10 - $15 at most.
If you are still having issues you will want to replace your router.
