Solution : Perform an Automatic Gradation Adjustment (Color Calibration)
Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
Hope it helps!
NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
Not a switch off/on can solve but a resetting .So remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
