Brother HL 1650 Laser Printer Logo
Posted on May 02, 2011
"Service Call Error E54"
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
12623
Points
38
This error code indicates a fault with the Main Motor. Either it's jammed or unusable. Unplug the printer from the power source, leave it for around 30 minutes, . While it's turned off, remove the cartridges, check for any damage, then put them back in. After tha, then reconnect it to the power and turn it on again. If this still doesn't clear the code from the display then you'll need to see a Brother service agent to have the main motor replaced.
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
What does error code e54 mean
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
What e54 error code mean on an electrolux dryer
Could be:
  • Voltage too low.
Dado
Error code e54
TEST this steps and fix it. This error code is E54 which is something to do with the motor.What you can try first is pull machine out and take off the back panel. From there you will see the motor at the bottom. Unplug the wiring block from it and start the machine again.
Ricoh ft3513 showing e54 what could be faulty
SOURCE: ricoh ft3713 error code e54, where is the fuser and thermistor
you need a tech. this code can be caused by a software problem in the main board. it can also be caused by the machine overtoning, needing a pm.
7helpful
Ricoh ft 3813 error E54
E54 is a fusing error. You can attempt to reset the code by entering service modes. To do that, you press CLEAR MODES key, then the numbers 1, 0, and 7 and then hold down STOP key. Once in service mode, press 97 then #. That resets the code. Power the machine off then back on to see if it comes back. If it does, then you may need main board or AC driver board.
2helpful
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
3helpful
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
2answers
Monitor ibm e54 coloure bluish background
please upgrade your graphics card if the problem still occurs then upgrade your os drivers...
Norman Weimar
Norman Weimar
k24674
