Nintendo Wii Console Logo
Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I go to the wii shop and it said error code:051030 and says cannot connect to sever.can you help me?
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
7255
Points
54
Hello IGWBR
You Have A Probleme With This Error : 051030
That Means :
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Anonymous
Level 2:
Scholar:
  • Expert 104 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
39819
Points
292
1 Related Answer
Anonymous
  • 24 Answers
  • Posted on Jan 07, 2011
SOURCE: Accessing the Wii Shop channel to install Netflix.
051030 is a 'too busy' error, so it's probably an issue with Nintendo's servers rather than your wii.
hope it helps dont forget to rate
When I try to go to my nintendo wii shop I keep getting error code 051030
That's an error code for wifi not being configured properly on the Wii. Check to make sure the Wii is connected to the wifi properly. Here is the support page for the Wii. How to Connect to the Internet Wii and Wii mini Nintendo Support
Here is some information on when nintendo will stop suport for the wii. Wii Shop closure announcement Nintendo Official Site
Error code 051030
Error 051030 information can be found here.
Wii will not connect with server. Error code: 051030
1RepairStop.com
Error Code: 051030
Bought a used wii and won't connect to the internet to run netflicks getting error code 051030
This is not an error with Netflix, but rather it is an error with your wireless network set-up. I have seen many people have trouble connecting the Wii to their home networks, and it does not appear to be very user-friendly. Here is the page from Nintendo's official customer support center about your error code and how to fix it.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
Hello.... trying to connect to Wii shop channel and i'm getting error code 051030... unable to connect to server... I originally had my server provider hook up everything ... and I was able to access Wii...
If you think it's a connection problem, go check out the Connection Settings in the Wii settings menu. Run a connection test, and make sure your settings are correct. Re-enter your WEP key and such if you're using things like that.
Error Code: 051030
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
* If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
o If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
o If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
* Check for interference that may be preventing a successful connection. Click here for tips.
* Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
* Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
1. Login to your router's settings (click here and select your router, if available, for information).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
* Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
* The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
* Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
* If the problem persists, try our general troubleshooting steps.
Wireless Channel
If there are other wireless devices in the area, they can interfere with the signal so much that the Wii console will not be able to connect to the router. Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1, and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab. =D
Keep getting error code 051030 unable to connect to server. we have wireless in our home which is working.
In this case all you can is try again later.
It can also be caused by interference of other wireless networks in the neighbourhood. If this is the case try changing the WLAN channel of your wii to 11, as most routers default channel is 6, this will give your fequency a bit of seperation from the other wireless connections.
Error code: 051030
error code 051030:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii or Nintendo DS online and test for proper response.
good luck
kc
1helpful
Accessing the Wii Shop channel to install Netflix. Error code: 051030 (unable to connect to server) any suggestions :)?
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
