Maytag MER5530 Electric Kitchen Range Logo
Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All of the sudden our maytag range flashed an "F 1" on the display and when we opened the oven the broiler coil was red hot and we were baking biscuits that burned to a crisp. Any insight you can give me would be nice. Thanks
Anonymous
Level 3:
  • Maytag Master 1,902 Answers
  • Posted on May 02, 2011
Anonymous
Maytag Master
Level 3:
Answers
1902
Questions
0
Helped
533581
Points
5669
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
3helpful
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
1helpful
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
1helpful
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
2helpful
Oven & broiler not heating on our Maytag MER5530. Lights on the control panel indicate it should be working. When I set oven temp, the oven "thinks" it's at that temp already. Turn broiler on and no...
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 • Ovens
2helpful
Mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
2answers
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
